justplain bill
- Apr 15, 2012
- 3
- 11
I have a Murray Select 13.5 hp, 40”cut, 5 speed.
Model # 405000x8f
Mfg 03/29/2005
Serial # 75074885 11 bs105
Engine will only fire with the kill wire disconnected from the coil.
After I disconnect the kill wire, the engine will start and run fine only problem I can’t get it to turn off using the key switch. Any suggestions will be greatly appreciated.
Model # 405000x8f
Mfg 03/29/2005
