Starting problem
Mike1132
I have a hustler zero turn model 926519. Cranks but won't start. Has new battery . Has a Honda 18 hp motor
Check to see if the choke is fully closing. Will this unit start if you completely close the carb throat with the palm of your and or drizzle a little fresh fuel into the carb?
