N
When it fails to turn over... Is it just silent when you go to 'start' position on the key switch... OR will it try to crank the engine But can not get past the first compression stroke...?
:smile:KennyVo,
KennyVo, thanks for response. Yes, it is silent when you turn key to start position. But, when using jumper cables to car battery it starts up fine. Perhaps because of greater amperage from car battery does the trick. If I don't use the mower for several days and I go to use it, it starts right up. Could it be the solenoid or the coil?
Thanks, Bill
