Starting Issue
shippy34
Hiyall, here is my situation. My Gear ring on my Briggs and Stratten 21HP engine busted into five pieces and i had to replace it. Here is my problem, i replaced the gear ring and had to drill three holes in the flywheel where the rivets used to be. i put everything back together and now all it does is turn over and not start until the battery dies.
Does this seem like a timing issue?
I am a rookie at this mower repair and i can use all the help that i can get.
There is a good possibility that the flywheel key sheared from not being torqued properly. Had one that turned 180 degrees once that was not properly torqued.
Welcome to LMF!!
There is also a good possibility you can post this in the 'Engine repair' section. :wink:
No need to post down here! You are free, since you already said hi and all! Post away in the regular forums - PLEASE. :biggrin:
Hey there - WELCOME to LMF!
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
