Starting Issue
shippy34
Hiyall, here is my situation. My Gear ring on my Briggs and Stratten 21HP engine busted into five pieces and i had to replace it. Here is my problem, i replaced the gear ring and had to drill three holes in the flywheel where the rivets used to be. i put everything back together and now all it does is turn over and not start until the battery dies.
Does this seem like a timing issue?
I am a rookie at this mower repair and i can use all the help that i can get.
There is a good possibility that the flywheel key sheared from not being torqued properly. Had one that turned 180 degrees once that was not properly torqued.
twall
Welcome to LMF!!
There is also a good possibility you can post this in the 'Engine repair' section. :wink:
No need to post down here! You are free, since you already said hi and all! Post away in the regular forums - PLEASE. :biggrin:
Briana
Hey there - WELCOME to LMF!
I moved your thread to the Small Engine & Mower Repair Forum. :smile:
