To me, the cam is dead. Lobes have shifted from where they were from new. New cam time.Toro 21472 that won't start. I tested it by spraying starting fluid into the air filter. When I pull the starter cord, the starting fluid sprays back out of the air filter instead of being drawn in.
It takes a lot of hours to wear down cam lobes. Are you just guessing this diagnosis based on experience? I have never seen an engine not run as a direct result of worn cam lobes.To me, the cam is dead. Lobes have shifted from where they were from new. New cam time.
Pull the cam and look at an online pic of a new one. Compare lobe placement.
Not necessarily worn but the lobes could of rotated ON the shaft throwing cam timing off.It takes a lot of hours to wear down cam lobes. Are you just guessing this diagnosis based on experience? I have never seen an engine not run as a direct result of worn cam lobes.
