Just because a spark plug fires outside the compression zone does not always mean the spark plug is good. You to try a known good spark plug. And yes I have seen plugs to fail after heating up too.
CoilI could be mowing the lawn for varying short lengths of time and then the engine just starts to miss fire and cut out, when I try to start it again it won’t start, I can leave it for a while, go back to it & it could start again straight away.
There was a little debris on top of the outlet filter in the plastic fuel tank which I syphoned out & there wasn’t any debris in the carb float bowl.
The change of plugs didn’t make any difference, also the plug wasn’t soaked with petrol either but it was sparking.
Regards.
"Featuring the lightweight 7.25 lbs gross torque, 163cc overhead valve engine featuring No Oil Changes ever." Cut and paste from advertising.Hi,
I have a 4 years old Toro 21766 recycler mower (photo attached) which has develop erratic starting & cutting out issues.
I have flushed out the carburettor & the petrol tank, replaced the spark plug & the lead but these problems still exist.
Please can anyone suggest any reasons why I’m experiencing these problems.
Regards.
Definitely not, I change the oil at the start of the mowing season."Featuring the lightweight 7.25 lbs gross torque, 163cc overhead valve engine featuring No Oil Changes ever." Cut and paste from advertising.
Please tell us if you followed this last **** piece of advice.
