ThatGuyYouKnow
- May 1, 2013
- 17
- 60
I need some serious help my friends. Im working now 5 days on a customers troy bilt pony 2009 model. I replaced a pulley and after hooking up the battery the solenoid started clicking when i would crank it. So after i started going through my methods of checking whether the starter was getting juice because it wouldn't do anything. Suddenly while checking a poof of smoke came out from under the shroud. I found the magneto burned. So i replaced it and the solenoid. Checked the starter it works. So i began putting everything back together and now when i try to put the negative cable on it sparks a little and engages the starter. It doesn't turn the motor over but it engages the pinion gear. New solenoid checked its good. I checked my cable to the starter and im getting 12v when i got from cable to ground with my meter. Im also getting 12v on the green on my solenoid. Its a 4 post solenoid. I dont know what else to do. I cant find any burn marks on the wires. I cant check the alternator because i dont have the bolt long enough for my puller. Please help.
