starter recoil fix
manny5520
How can I fix the starter recoil eyelet on a 18 horse kawasaki pullstart without buying a new starter recoil? The hole where the rope goes through is all worn out and I keep breaking pull cords. I is there any way to fix this without relaxing the whole cover? The cover and the eyelet are both metal. I no rebuild kit available...
pugaltitude
Can the eyelet be spun round?
I dont mean taken off but hold the recoil, pair of pliers and spin it round so you are using different part of the eyelet.
Some are designed like this for this reason.
manny5520
Thanks for the advise. I I ended up drilling out the center of a 3/8th nut and welded it to the cover after I drilled out the old one..
manny5520
The eyelet was wore thru all the way into the metal housing..
reddragon
hardware stores have plastic inserts that could work...i used one last year on a clutch cable on a firewall
midnite rider
You could also use a rubber grommet but welding a bored out 3/8" nut is a great and inexpensive fix. :thumbsup: You shouldnt have to replace a rope for a while now. Did you mount the nut flush with or 1/2 way thru housing?
manny5520
Flush. I just matched it up with the hole from the inside.
