PTmowerMech
- Apr 16, 2018
- 424
- 3,243
John Deere GT235, with Briggs 350777 1137-F1
Nothing coming from the key, so I put the jumper on it, crossed the solenoid with a screw driver. The gear spins very strong. But it's not coming up to engage the flywheel. I used a 90 degree pick to get under the gear and pulled it up. And it came up without having to pry it. It wasn't stuck on anything. When I remove the pick, it goes back in place a little slow. But within about 2 seconds its back back where it starts.
I've never messed with these. Is there a reason it's spinning fine, but not going up?
