Starter question Murray 10/30 Tecumseh 10hp
dmcinpa
Hi all,
New to the forum, and new to Murray.
I have acquired a 10/30 as I've moved to a smaller house with less land and, didn't need the 46" MTD that I previously had.
The Murray was running a few weeks back, but I broke the key off in the ignition and it has been sitting until yesterday when I replaced the ignition switch and the solenoid and battery.
When I crank the 10HP Tecumseh without the plug it seems to sound fine, but with the plug back in it sort of goes whir wuh, whir wuh, whir wuh, as if it doesn't have enough to get it started.
It has the new battery and other pieces, so I figure that's all that it could be. When I short the battery to the starter terminal the same thing happens. Could the starter be weak?
Where would I get another starter for this mower, or should I have the local alternator/starter repair shop "redo" it?
Thanks... any help appreciated!
DMC
You should be able to get it rebuilt for under $20.
Or you can go to napa and get a new one for $50.
But just for fun pull the mower over to your car and put jumper cables on it and see if it cranks better. I know you said you have a new battery but you never know.
Sent from my iPhone using LMF
