Starter Mounting Screw Help!
BigWeakSauce
I'm struggling mightily here to identify the thread I need for the starter mounting bracket for
  • 33R877-0002-G1
The active part number for the screw is 791680 but I'm trying to avoid paying $8 per screw with shipping (and waiting 2 weeks) when my local hardware store certainly sells the same screw for 10 cents.
Anyone out there know where to find this info?
  • 33R877-0002-G1
Go to the hardware store with the bolt and match it. They should have a sample you can screw the bolt in to determine the thread pitch and diameter.
5/16-18 approximately 5/8in length and the use of a lock or flat washer. Briggs uses a flat washer. Note the RH screw will be a lot harder to install using standard hex head screws. This is because the starter Bendix being in the way which is why Briggs uses a hex head with a T-30 torx drive. May need to remove the flywheel to get the RH screw installed.
To clarify, RH means right hand? I can see that being a pain to install. I ended up paying $7 with free shipping for a set of 2 OEM screws, just biting the bullet and waiting on shipping. And then I'm off on my way to figuring out what other surprises await me when I turn the ignition.
