ST 4175 string Trimmer
GM Guy
Hello All.
I have a ST 4175 string trimmer that dies just off idle. I replaced the fule lines and it was running normally and then it studdered and died.
I can restart it easily but it dies as soon as I open the throttle.
Any ideas??
If the tank is full. tip 1/2 of it out .
If it will not start at all then the lines you just replaced are wrong way round
Thanks for your reply.
It will indeed start and idle with less than a full tank. It simply will not rev and dies .
The new fuel lines are clear and I can see that they’re full of fuel.
Now comes the hard bit
If it has a rotary valve carb then the check valve on the high speed circuit is probably stuck closed and that ie a fatal flaw as they can not be replaced
If you have a butterfly valve carb then the High speed circuit is out of adjustment
If it goes fluffy , blows a bit of blackish smoke then the H is too rich
If the exhaust sounds sharp the stops abruptly the H is too lean
Some times if you take the carb off but leave the fuel lines on, turn it sideways & blow compressed across the venturi a lightly stuck check valve will start to flow
You should see fuel mist blowing out the carb .
Thanks very much!
It has the rotary valve carb.
I suspected that it was a carburetor problem although it happened so suddenly, I had never experienced a carburetor problem like this. I’ll search for a carb kit or a new carburetor.
