SRM225 WONT RUN
The Rock
Do a compression check. If under 100 psi you are wasting your time.
As far Amazon ratings are not reliable either as several of my own bad reviews were never psoted or was deleted . Most related from poor to no customer support after the sale. I am currently working on a Murray pressure washers that was received with a bad battery that Amazon vendor refuses to replace and customer just got less than a month ago.
Ok Thank You
