New NGK BPM8Y plug, fuel line, filter and cleaned the spark arrestor. Had to removed the little plugs in the carb so I could adjust it. Got it started, adjusted it what I think is spot on. It idled pretty smooth, had lot of power on the WOT. Let it sit for about 10 minutes and it fired right up, without the choke.
Let it set about an hour and it's right back to trying to start, but just won't. Almost every pull, I get a little something, like it's gonna start. Like a "hubba hubba" sound. With the choke on or off. With throttle pulled or not.
It almost sounds like the timing is off or it floods easily. But this is the 2nd time this has done this. And once it does start, it runs and idles great.
Plug is wet.
Any advice would be appreciated.
Plug is wet.
