srm-230 weedeater H carb screw setting
ugabulldog
I removed the plastic limiter awhile back, and am trying to adjust high speed screw, I have turned it cw, ccw and can't seem to tell much difference, can someone please give me the approx. setting? (XX's turns CCW from seat) thanks
Fish
To get the "original" settings before the limiter was put on, you will need to warm up to an Echo dealer at least, but one thing is likely sure, you need to
correctly go through/rebuild that fuel system/carb-etc. if you want it to run correctly....
MRCo.
I usually do 1.5 turns out on both needles as a start point and then go from there. If you can turn it more than one turn either way and don't notice a change then it's a bad sign.
