squeeky Toro
IRON
I have a Toro 4260 Zero turn and it squeeks a lot after it has been running for about a half hour. The squeeks appear to be from the rear wheels however I see no place to lube the wheel or axel. The front wheels also squeek a little and I have lubed thm by way of the greese fittings. Any help will be appreciated. Thanks nickpicker
Hey buddy dont know about the rear wheel squeek
but if you remove the front wheels and take the steel
axle tube out and lube it by hand it should work
good luck
