Squeaking noise followed by smell of burning rubber
Fourester
2014 Hustler Raptor, 42" cut. When I engage the blade belt, I hear squeaking coming from the deck area after a few seconds of running, then the smell of burning rubber. I know it could be several possible issues. Is there any way to check things and narrow it down?
Well it sounds like you're burning the belt , there is a good chance there's something caught in one of the blades, the sound you're hearing is the belt squeeling , with the engine off , grab one of the blades and try and rotate it , it should turn freely
I'd start with a visual check of the belt and pulleys with the engine off. Look for any signs of the belt rubbing, frayed edges, or something caught around a pulley. If nothing obvious shows up, check whether the idlers turn freely and that nothing looks out of place. With the squeaking and burning smell, I'd avoid running it much until you find what's causing it.
