Sprayer attachment
Its hard to see in the picture but the rack has supports that run at angle forward in front of the motor and attached just behind the seat. Weight should be centered over the rear axel not behind. Haven't fully tested it yet, but my lawn is flat so should not be an issue as long as I don't "hotrod" around.
I'm not knocking it, quite a great idea. Can always add counterweight to the front beam if found to be needed.
