sport 48" loud blades
McGee10
anyone have loud whirling noise when blades are engaged?
Is this a Known Problem?
Thanks
Mike
If the same in past has not made this noise then the spindle bearings are most likely going bad.
McGee10
It has made the same sound from day one
I purchased the mower new
7394
Are they Hi-lift blades, those can make more noise.
SeniorCitizen
Mow about 10 minutes and shut the engine off to check bearing housing temperature by feel . If a bearing is bad , the temperature of that housing will be above the others .
Occasionally a grass build up of clippings will cause a odd sound.
Is this a trick question? That is what a mower sounds like when blades are spinning.
No, If blades has always made the same noise then it is the blades. It is when the noise changes that something has changed. Different blades due to design makes different noises. Usually it is an air noise just like helicopters rotary wing makes a lot noise on lift off but has the wing gets feather out the noise is reduced.
