spec help on GXV160
GXV160K1 type A1AS serial number GJ03 6240879
Engine family 2HNXS.1631AL
meets 2007 EPA
Carb tier II 2006 compliant
Can someone please confirm valve clearance specs for the above? Seeing/reading/Google/Honda manuals in pdf IN 0.006" and EX 0.008" and 0.004" for both.
Have a 2005 GXV160 Honda owners manual. States 0.004" for both valves.
Thanks to your tip I got a better manual, the one you linked. Appreciate it sir. I was having trouble just looking at the GXV160 model numbers which they have a ton of. Much easier using the serial for this one. (y)
Another thing that threw me was the mm conversion. Quickly looking at it I "thought" it was 0.004", WRONG. Big dummy. :oops:
