I tried to change spark plug today. Got replacement identical to original but I cannot get the spark plug to screw in. In fact I tried to get the old one I took out to screw back in (just to experiment) and it wouldn't go back in either. I don't think I have stripped the threads to this point. Any tips for making the screw threads turn? The only thing I've seen on the Internet so far is a suggestion to put soap or wax on the threads to lubricate them-- however, this was for wood screws in lumber.
FYI, What is happening now is that I get the spark plug to screw in for a couple of turns, then it tightens and seizes up. Same place every time. My mower has always been serviced by mechanics. In fact, I couldn't say for certain that the plug has ever been replaced.
Troy-bilt Pony mower. Briggs and Stratton 17.5 hp engine.
I'm thinking there may be some really good lubricant built just for this purpose. Is there a way to make sure you line up threads correctly? I don't think there is grime in the threads but there may be. Best way to clean the threads. Any other tips, etc.
Thanks,
Richard
Thanks,
Richard
