The one on the left I could see, but the one on the right shouldn’t be that black, should it?No, these plugs look typical for the most part. Overheated, if anything, not rich. Rich running would be dark black soot (unburned fuel), all over the porcelain and threads, that could be wiped off.
FOD? Wow! That is a military term I have not heard for a while.Yes, both NGK BPR4ES. Single throat carb.
No FOD in the cooling fin area.
Comes back to haunt ya! lol!FOD? Wow! That is a military term I have not heard for a while.
Like I mentioned earlier, I would use Champion plugs. They should be RN12YC but double check the application number.
