Spark Plug Location? Craftsman Riding Mower RZ125H42B
Shawn R.
  • / Spark Plug Location? Craftsman Riding Mower RZ125H42B
SERIAL #072401D001075
This is an old mower that still runs. I was having an issue where it would run for about 20-30 minutes then slow down until it stops. If I let it cool off for about 20 minutes, then it'll go again. I've been seaching for the spark plug but haven't had any luck finding it. I noticed that on other Craftsman Riding Mowers, the Spark Plug or Plugs is located on the left and/or right side of the engine compartment. But on this one I can't find it. I think that maybe the Spark Plug has gone bad or something. Any info would be greatly appreciated!
Which engine do you have on that mower. If it happens to be the Kohler courage single cylinder it is top center buried inside the blower housing Need to remove the blower housing to access it the easier if you have that engine.
Shawn R.
I have no idea on the engine type. But I was told it's it should be labelled as a Rally mower (AYP/Husqvarna/Craftsman mower).
