this ^^^^^Goes over the air screw I'm guessing. An EPA item of sorts.
yes thats the piece is it optional? I don't see where its suposed to go?I will check for cracks thanks sgkentthis is the piece we understood that you were asking about.
Make sure there are no cracks in the plastic manifold.
OK so it is optional for me? or could it act as a lock where the screw stays put? thanks sgkent I hope to get her back together in next few daysIt is designed to go over the adjustment screw after the small engine technician tunes the mixture. It is designed so that the consumer end user, e.g., you, cannot tamper with the settings and change the emissions of the engine.
yes definitely something inside carb. I actuely dissassembled it the float wasn't punctured I'm no carb expert even a simpley one like this. so opted to replace an hopefor the best.Sounds like your carburetor's float needle isn't sealing properly when the engine is off. What happens is gas slowly leaks past it and pools up. Then, when you go to use the choke for a cold start, it's just way too much fuel and it instantly floods the plug. Before you touch any of the carburetor adjustment screws, I'd bet that pulling the carb bowl off and giving the float and needle a good cleaning will solve your problem. It's a very common issue on those Intek engines.
it was so strange to see fuel shoot up in air
