I've got an electric start Subaru 9hp EX27 that I'm trying to get going. It had no carb, ignition switch or diode rectifier when I got it. I got a new carb and ignition switch, got those hooked up. I am waiting on the diode rectifier but I wouldn't think that would have anything to do with the engine not starting, that should just be for returning charge to the battery.
Anyway, I accidentally grounded the kill switch wire that goes to the ignition coil to one of the wires coming from the 200W charging coil that should connect to the diode rectifier. It fried the ignition coil. I ordered a new ignition coil and installed it. I'm not getting spark. I had two or three various other plugs laying around so I checked them and one of the smaller plugs showed a weak, intermitten spark. The correct plug shows no spark at all. I've checked the proper gap for the ignition coil. Any ideas or suggestions?
