Export thread
Spacing spindles with washers?
#1
W
whitepony04
D110. One of my blades sits slightly lower than the other, measuring tip to tip in center of deck. Can I use washers between the deck and spindle to correct this? The blades are new and straight.
#2
Boobala
Boobala
Did you know that in WW1, when they mounted a rapid fire machine on top of the fuselage so a pilot could shoot down enemy aircraft , at first , they shot themseles out of the air ( machine gun hit THEIR OWN propeller... UNTIL , thy figured out how to make the gun ONLY fire when the blade was horizontal to the fuselage ( fast-bursts albeit) NOW ... do you think your blades will hit each other with your "modification" ...??
#3
W
whitepony04
They dont
#4
Boobala
Boobala
They dont
Then I would just shoot the *&@#$%#&&$# following you with a ruler ..!! ..:laughing: ..:laughing:
#5
W
whitepony04
Is there any detriment to using washers to lower the spindle slightly?
#6
TJR345
TJR345
Which way is it lower,are you measuring the blade tip on the side or to the front.
#7
W
whitepony04
If u point the cutting edges of the blades towards each other at the center of the deck, there is a slight difference (rotatated blades and same discrepancy existed) I took the spindle off and put 4 lock washers between the deck and spindle to lower one of them. They are now very close to being even.
The blades engage and sound fine, just need the grass to grow to see if I improved cut.
#8
TJR345
TJR345
Did you hit anything you may have a bent blade.
#9
W
whitepony04
The blades are brand new and I haven't hit anything. I replaced the factory mulnch blades with gators. One of the factory blades seemed bent because I was getting different measurements on each side of the blade with the deck leveling tool.
#10
B
Which blades are you using.
The round hole or the star hole.
Some times the star pattern gets a bit too much paint in the hole and does not sit as close on the spindle as it should.
And occasionally if you use an impact gun to do up the bolts the stars can get a bit skewed.
I am a professional & I have done it more than once ( to my eternal shame )
Did you replace the spindle bearings when you did the blades ?
Could be a tight bearing not properly seated
#11
W
whitepony04
Star hole. I didn't impact the nuts. Whole mower only has 6 hrs on it so no beatings replaced.
#12
B
How far are the blades out ?
Did you try swapping the blades ?
Is the nut on the top of the spindle tight ?
This is a bit on the weird side
#13
W
whitepony04
There was about an 1/8" difference. I can check the spindle nut tomorrow and give an update.
#14
TJR345
TJR345
When you measure the blades for level first be sure tires are properly inflated.Next turn the blade so they are side to side.That should be level on both blades (3" for example) Then turn so they face front to back.The front facing blade should be 1/8 to 1/4 lower.
#15
W
whitepony04
As of right now, everything is tight, blades are within a 1/16 of each under in the center of the deck and side to side the deck is level. Also the front of the deck is about 1/4 lower than the rear.
This is all with the washers installed.
#16
W
whitepony04
Update: just finished the yard and the cut is better than it's ever been. I rechecked the spindle bolts and they are still tight. Should I lock-tite them?
#17
B
no locktite.
