Sovereign manual PTO clutch hub
kgrabow
I have a sovereign believe to be 90s that the friction material has gone out on,trying to find new or used replacement,pulley ok just need help on where to find, or if someone applies new friction material thanks kevin
You will have to supply us with the Simplicity model number so we have some idea of which unit you have. Your post does not make much sense. Lease reread your post, as I suspect you have used a translator program when posting. We need better info from you to help you solve your problem.
