I have a Southland Wheeled Trimmer SWSTM4317.2
Last summer I replaced the fuel lines and primer bulb and got it running good
This year I started it up and was using it and the trimmer was turning when I gave it gas
But that all changed!
As I as I was giving it gas (pushing down on the throttle handle) the trimmer head stopped moving
I would start out with it running and the trimmer head turning and then it would not turn no matter how I pressed the throttle down
The trimmer head does not turn like it supposed to when it idling
And when I give it gas it turns like it supposed to but with giving it gas the trimmer stops turning and stalls
Is there a clutch problem it holds making trimmer head move and stops turning after a little and stalls
