solenoid
joe74
My starter solenoid quit working. you can jump the starter and it run fine.Is there a fuse for this? Thanks joey!
Well without the model number I would you probably have a bad safety switch since the mower will run as most nowadays have a fuel solenoid that need power too and the fuse was blown it would not work either.
joe74
It's a hds 2165 and old owner by passed all safty switchs including fuel solenoid , he cut the the rod going into carb. Thanks joey !
