I have a XT1 Enduro Series LT 46 in. 22 HP V-Twin Kohler Hydrostatic Gas Front-Engine and Solenoid just makes a clicking noise.
I replaced the Solenoid and still makes a clicking noise, Battery is new and starts my other mower, from the battery to the Solenoid is showing 12 volts but only showing 6.7 volts at the starter when I turn the key using a multi tester and touching starter bolt, I know it should be 12 volts but not sure why its only getting 6.7 volts.
Can anyone suggest what the problem could be
Thanks RonV
Thanks RonV
