PTmowerMech
- Apr 16, 2018
- 424
- 3,242
I ordered a 2000lb wench today. Gonna use it for 1 of 2 things.
A 4 post mower lift, that works off the wench. My idea is similar to a 4 post car lift. Except there won't be as much steel involved. 4X4 wooden corner posts. The wench will be attached just in front of the lift about 3 feet. Cables will be ran along the side of the post, and connected to a single cable that goes to the wench. Of course, the 4X4's will be braced.
The mower wheels will roll up on two 2X6's (Maybe 2X4's). There will be two 4X4's that will go crossways under the 2X6's, to the corner posts. On the ends of those post, will be some sort of wheels. Probably 4" idler pulleys, that will go inside a a track. The 4 cables will be secured to the two 4X4's that run crossways under the 2X6's that the mower sits on, with eye bolts. The cables will also go through other eye bolts up the corner posts, to keep them in place.
Getting the mower up high enough may be a problem. I only have about 10ft from the ground to the roof of the shop. The mower is gonna take up a lot of that. And the cable mounts will take up some room as well.
It's just in the "think about" stages right now.
