Snowking 8/27 rough running
Before pulling the tank try this. Run the unit until it stops. Immediately remove the fuel line from the carb and check fuel flow. If the fuel flows freely, the float needle is sticking. If the fuel flow is slow, then look at the tank for blockage. Is your fuel shut off mounted in the bottom of the tank or inline?
riseandrun
Originally when it quit I did pull the gas line on the "carb" side of my in-line shut off valve. It was flowing, but not like what I would expect. That's why I was thinking it was something with the tank. Thanks for the help so far.
R&R
