davbell22602
- Nov 27, 2011
- 152
- 1,324
Considering buying another snowblower but cant buy it til the spring in April or May. I have a Sears 247.888500 26in 8.5hp track snowblower but it needs new connecting rod. Got it from PO in pieces. PO said he was blowing deep snow with it and snapped a rod but no other damage to the block etc. It does have the aluminum markings on the crank journal. Its one of twin cam engines that are to find replace it if I needed a engine. I'd still fix this one regardless. Im just not comfortable depending on this one at one that I'd use all the time. Much rather keep going as back up snowblower. I have 400ft driveway that I would it for. The driveway has hill up by the house then dips down then back up to the road. Im using Sears GT3000 with 48in dozer blade but not if it climb the hills with snow on the ground or not. So I'd make due with GT3000 til spring got here.
These 2 caught my attention from Home Depot.
http://www.homedepot.com/p/Poulan-P...396?N=bxc5Z12laZ12lbZ12lcZ2bctpx#.Uqdl2SeaaB4
http://www.homedepot.com/p/Sno-Tek-...490?N=bxc5Z12laZ12lbZ12lcZ2bctpx#.UqdmmCeaaB4
