snow plow for a rer snapper
cablesnmoore
got the plow for $35 figured i would make it work made it bolt on takes me probably 10 min to put it on first pic is what i started with it had all the bolts and the controls second it the modified bracket held in place i will get more pics when i start to clean it up and paint it i think im gonna paint it the snapper colors
hers a couple more pics of it cleaned up and painted i ended up just doing it a flat black for now its what i had it looks better then raw cobbled multicolor mess i can move the mount of the blade up a notch and get another 2 inches or so of lift i just wanted to see how far up it was on the lowest mount the weight box you can tell its just a cinder block i filled with concrete around 75-80 i havent weighed it but its heavy it bolts on to the original hitch and slides onto the mount for the bagger i made it long so i could if i needed to pull my yard trailer with the weight box on it
nice. i just built a grader out of a snapper i got. total cost...5.94. has a ripper blade too.
Nice to see some minds working out there.
