Snow Plow Down Pressure
JD75
I have a JD X320 with a plow. I was trying to spread gravel earlier today and I had problems with getting down pressure on the blade to be able to push.
Is there any way I can get pressure on the blade?
Yooper75
Is it hydraulic or manual lift? If it's manual lift the only option is to add weight to the blade which will add it's own unique problems.
JD75
Manual. I'll give the weights a try
brakerpa
Try reducing tension on the spring assist.
valkyrie1
HI
weight will work but just rember the weight you put on you have to pick it up
the only thing wrong with the weight. hope you are strong in that arm. :smile:
