The Brain
- Jun 26, 2019
- Threads
- 8
- 58
Snapper won’t start no 12VDC at starter
2009 Snapper 23 series,12.5HP,30" blade,electric start.
I have tested the ignition switch w/ key on I have continuity to all wires from ground except the blue trigger wire.
When I turn the key to start I have I have continuity so I assume the switch is normal.
When key is start position I get 12.7VDC at the back of ign.switch same as input of soliniod. so after wasting a few hours dicking around decided to bypass whatever safety switchs there are.
so I extend a grey wire spliced to blue behind switch however when I connect to trigger spade 3rd terminal of soliniond voltage is reduced down from 12VDC to 2-5VDC fluctuates increasleing not past 5VDC.
I’m suspicious of the new soliniod functioning correctly.
Here’s a few images maybe I missed something. thanks for advising TB
