Have older model Snapper Weed Eater that has set up for a few years. Took it down and put gas in it and it starts fine and runs fine up to about 3/4 throttle. Try to run it past that and it will die. I've cleaned the carb 3 times, and also cleaned the carb with carb cleaner. Same thing 3/4 throttle is it. There are no adjustment screws on this carb and a new one they want over $200 for it. I don't think so! If so I'll just use it at 3/4 throttle. Anyone have an idea I haven't tried or a way to fix?
