snapper riding mower will not go foward or backward
rjester
snapper riding mower will not go forward or backward
exotion
Good story bro....
If you want help you really should give us more info.
Model number is a good start and any symptoms you had before it broke or currently could help the people diagnose your problem
DaveTN
Usual culprit in that case is the rubber-lined friction driven wheel that is not properly contacting the drive plate from the engine. There's an adjusting gauge, an L-shaped looking thing I believe that you set it with, then tighten down. Been a while since I used one, but I think we took the original gauge and made a duplicate one out of wood and worked fine.
