incognito123
- Sep 9, 2012
- 3
- 4
I purchased a Snapper RER less than a year ago and when I pulled it out yesterday to mow for the first time this season, I noticed a problem. The mower starts up fine, but when I put it into gear, it will not go. It will start to go if I use my foot to build momentum, but will only do that a few times before refusing to go at all. Reverse doesn't work either. This mower has less than 5 hours on it. Any help will be appreciated. It is still under warranty, but I am two hours from the nearest Snapper dealer and would like to aviod that trip if at all possible. Thank you
