Snapper 28 RER HiVac
While mowing today lost something in the drive train.
With engine off,
Rubber tire is engaging drive plate when in a gear.
But tractor rolls back/forth as no connection between rear wheels and rubber wheel.
If I am in neutral I can roll tractor back forth -- I can see rubber wheel moving in concert -- but I can easily hold and stop rubber wheel from moving.
I I squeeze the dust guards on main wheel shaft I can feel a hex shaft rotating, but I can easily hold and stop that shaft from rotating with rear drive wheels rolling back/forth.
If I put into gear then rubber wheel engages plate and cannot be moved, but rear wheels roll freely.
Advice appreciated.
With engine off,
Advice appreciated.
