Absolution
- Aug 4, 2019
- 4
- 13
Hi all,
I don’t normally ask this since I usually know model numbers etc etc.. but I recently got a snapper 28 inch hi vac that I believe had an 11.5 intek with a pull start/electric start combo. I’m unsure of what model number this is as the sticker has been removed by the previous owner. I swapped a 17.5hp brigs i\c on it. It runs perfect, but I’m not sure what belt it uses since the belt is loose. It had a new blade and everything on it when I got it. Simply needed the new engine and belt. Does anyone have any ideas? I added some photos of it that may help.
also did they have this weird push button start from the factory? I am also not sure if the engine is charging the battery as there isn’t anything connected to the stator….. not sure how I’d wire that. Thanks!
