Kawasaki FT721V motor. Last season, the motor ran fine. This season it wouldnt start. Changed the plugs and it ran great all day, next time I started it it ran really terrible. I figured the old original carb was just wore out, so I bought a new carb and replaced it and it did the same thing. Now it will only start and run if ya keep hitting it with starting fluid. Here is what I have checked. Check the gap between the flywheel and coils Changed plugs. New carb and mounting gaskets. changed fuel filter. pulled line off fuel pump and it's pumping like a champ. Everything other little thing I have tried did nothing.I tried putting my hand over the air intake and that didnt change anything either. Doesnt matter whether the choke is open or closed, it still will only run if ya keep squirting it. Can I get some educated opinions of other things I could try? Thanks y'all
