Snapper NXT 2346 - Electrical Troubleshooting
Steevo
Hi all. I've had my Snapper NXT 2346 for a couple of months. All has been fine until yesterday when the PTO switch stopped engaging the blades. I was suspect of the switch itself, and then I noticed that the headlights don't work either. Battery has good charge. Push-button start/stop seems to work normally. Electric mower deck height works. The mower has been used in quite a dusty environment lately. Are there any fuses between the PTO switch and the PTO clutch? If anyone has a link to a schematic for this model it would be greatly appreciated! Thanks.
I recently purchased a new Snapper as well. If you go to snappers website and navigate to the support tab, you should be able to input your model number and pull up a parts breakdown. You should see a wiring diagram toward the end of the document. Hope that helps.
Followup to my original post. Turns out there is a ground wire that passes through the chassis and there is no rubber grommet in the hole. The wire rubbed against the hole until it finally broke. Once I reconnected the wire everything works. Still having electrical issues though. I hope this isn't a pattern developing.
