Snapper engine reviving
Some mowers have a filter in the tank and by adding a second filter depending on filtration can cause a fuel restriction.
Thank you,it didn't have one when l got it , quick question the larger the diameter of gas line matters
Most rider fuel lines are 1/4 inch ID,
I have two sizes on hand l know one 1/4 inch ID and one is a tad bigger.l think somewhere between the tank and carb is a restriction and maybe as previous mentioned by an experience mechanic.
