Snapper Bearing 7015319YP
rswhitmore
Where can I find a couple Snapper/Briggs&Stratton 7015319YP Bearings, or a cross reference bearing. Everywhere I have looked says no longer available. Someone has to have a couple of these.
rswhitmore
Bearings not available at either of the above sources. Actually ordered them from SLE, but they came back a few days and cancelled the order. If anyone actually has a couple of these IN-HAND let me know.
Two things you can try. Remove one bearing and clean the exterior very well. Most times bearings will have their manufacturer number stamp on them. If no numbers are there take the bearing to an industrial supply company and ask them to measure and match them. I’ve used companies such as Grainger, Motion Industries, etc. A good machine shop will probably have tell you who they use.
rswhitmore
Thank You.
seagiant
Hi,
This is an Axle bearing?
Steel or Nylon?
Running into different things with this number?
rswhitmore
