yes, plug is oily and carb was purchased from Parts Tree. After replacing carb, head gasket, resetting valve clearances, oil change, fresh non ethanol gas. No change.is the plug oily?
also, where did you get the carb?
Briggs 111P05- 0008-F1 7.75HP (175CC)
What's the make and model of the Engine?
