Only when in Park (Brake applied and locked), there is a tremendous a mount of smoke coming from underneath the rear of my mower. Smells like burning rubber!!! I thought it might be coming from the drive pulley belt. Checked it and it looked like it was twisted over on the pulley under the mower. Flipped this over, but problem persists. Belt is not hot. Tension on belt looks OK. Rubber drive tire looks ok.
When in gear and moving, I don't see any smoke coming out? Other than this everything seems to work normally.
Any ideas what to check next???
Any help will be very much appreciated
