Snapperfreak
- Dec 13, 2011
- 22
- 676
So my OCD enabled me to find another gem yesterday on cl AND be the first to call about it. I will get pics posted later this week but it's a 1982 21350PS...key-start. 1982, being the last of the non-OSHA engine-kill handle years, it has the vertical-recoil Briggs 3.5hp engine and red rubber drive handle cover. I bought it from the original owner who also had an extra bag and a brand new blade for me. The only reason he sold it was because the recoil began to get hard to pull. Last year he had it serviced at a local shop (new belts, carb cleaned). So after fighting with the recoil on and off for the last year or so he called it quits and bought a new Honda from home depot. When I got it home and played around with it I noticed that the belt that goes around the shaft was pretty tight and the shaft actually spun while the belt stayed put so somehow there was too much tension. So today I took the spring off to release the tension and it started on the second pull. The engine runs great. So all I have to do is figure out thae tension issue. Oh, and the key start has a minor issue...it's missing the starter. Even though I'm sure I can use it as-is with the recoil (once the tension issue is fixed) I really want to get that starter so it's back to original shape. It has the tray for the battery down on the deck just to the left of the model/serial # decal. It's really neat and I can't wait to get pics on here. I'll get some before and after, as it's pretty dirty right now.
Almost forgot. I got the mower, two really good condition old bags and a brand new blade for $30. Not bad.
