Snapper 21" "M" Model Series 15
blaster 2023
MRP216015B The Driven Wheel shaft was worn as were the snap rings.
The "Shim" washer was missing. I am waiting for the shim washer. What is the purpose of the shim washer (29)?
Auto Doc's
The shim washer was left out by an idiot (just a guess). It is what sets the correct side clearance for the assembly to work. It prevents it from walking back and forth and slipping under load.
blaster 2023
blaster 2023
What prevents the Hex shaft from spinning in the Bearing instead of the bearing and hex shaft spinning together or
How was it engineered to work? The Snapper manual implies the shim on commercial Mowers. Shim 29.jpg
Auto Doc's
There are roller bearing inside between the hex portion and the outer portion.
